Not bad at all.
Is it worth getting a 280x for $219 (+$90) instead ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103143
http://www.anandtech.com/bench/product/1039?vs=1041
70% more money, for similar increase in performance is up to the buyer's budget, and if they want to go red or green. Different class of cards that shouldn't be compared. $220 isn't exactly a good price for a 280X anyway, especially a Diamond.
I have a hard time finding 280x's new for under $250. Where have you seen them cheaper?
I'd love to find a 280x (not 280) for under $200.
Forum price is about $140-160 used, $160-190 new depending on model. I just got a NIB XFX DD for $150.
So basically...you don't have a better price for a 280x new at an e-tailer.
What does that matter? Why would a member here pay nearly $100 more just to get it from an etailer? It doesn't change that $220+ isn't a good price for it. Most brands now do warranty by serial so it doesn't matter where you get it.
You can also get them on eBay new for about $200.
What makes this 660 a good price is how its the same as forum prices.
