Krenum
- Apr 29, 2005
Hello everyone, I recently acquired a used GTX 760 OC MSI card:
https://www.msi.com/asset/resize/im....png62405b38c58fe0f07fcef2367d8a9ba1/1024.png
Having problems with it. I've installed it on two machines with the same result. After installation when I try to power the computer on all of the fans spin for a millisecond but the machine doesn't turn on. Both machines have well above the recommended 500W power source needed to run the Graphics Card with 2-6 pin connectors.
Is the card dead? Or is it not getting enough power? Have any of you encountered a similar problem? Please help. Thank you.
