warmish I'd say.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127502
The cards are designed to run that hot. People fuss too much over how much heat the GPU produces. It is given how highend of a product the 480 is.
Sorry, it's $364.99 AR.
might wanna add that to OP.
Considering 5870's are going for ~$220, no thanks.
Some haven't and that's why I posted it. Way to take video cards personallyAhhh yes, the inevitable I can get an ATI XXXX for $XXXX reply. I was just posting a decent deal for a specific card. We've all seen the comparisons, thanks.
This is a foolish and ignorant assumption. Even basic engineering research will show you how wrong you are.
And opinions from one person are worthless... Especially when they are not even close to being accurate. Too hot for you does not mean too hot for someone else. And the GTX480 was engineered to deal with running that hot for years.
I have dual GTX480s and I have zero issue with how hot they run. I also run the fans on automatic, and if you are gaming and have any sound on, the sound from the cards is a moot point...
