Activate: AMD
- Nov 6, 2004
1050Ti probably can go higher, most are hitting 1900, it seems the ones that aren't able to keep their clocks at 1900 are the ones that have poor coolers. I really don't think there is much difference between 14nm from GF and TSMC's 16nm, outside of the transistor density which would have a direct link to the heat. And it being such a small chip its harder to remove that heat.
Yea I guess thats exactly my point. NV's cards have had higher clock speeds for a long time so its not shocking, but I thought some of the perf/watt or clock discrepancy may have come down to the process, and that really doesn't look like the case.
