MSI Core Frozr S for Ryzen 9 3900x
Nidhalof
Hi
i'm upgrading to a Ryzen 9 3900x and the stock cooler is not enough to keep that beast cold, i have a core frozr S with double fan setup is it enough or shall i buy something else ??!
Thanks
Enigma
The Core Frozr S should work just fine, I however would recommend some thing from noctua if you intend to overclock.
kirbyrj
https://www.techspot.com/review/1875-ryzen-3900x-wraith-prism-rgb-vs-liquid-cooler/
Here we go again...the stock cooler is actually good enough. If you're going to upgrade, your looking for something quieter, but you're not going to get a lot more boost performance just out of a new cooler.
I certainly wouldn't spend $65 on a 4 heatpipe 120mm setup. You might as well get a Coolermaster Hyper 212 for less than half the cost. I can't find a review for the "S" but the larger "L" wasn't a great thermal performer.
