First, I should preface by saying I am NOT a big overclocker. I typically do a minor overclock and sure I like to game, but primarily this will be a work system (which includes lots of video editing). My priorirties are stability, performance and features.
Until now I've sworn by Intel motherboards - sure they're typically expensive, low on frills and may not perform the highest, but they've all been utterly stable and a joy to use. My current 3.5+ year old D975XBX2 system has been on 24x7 and never once given me a BSOD. An older system I built in Rambus days ran for over 8 years straight without issue. However I absolutely cannot stand Intel's lackluster X58 board, so I need to turn elsewhere, and not having used any other brand in quite a while I need some advice.
I'm looking to pair the board with a 980X + Thermalright Venomous-X, 12gb DDR3, Sapphire Vapor-X 5870, X25M 160gb SSD, 3 x WD Caviar Black 2TB, all in an Antec P183 + CP-850.... plus misc other stuff.
Right now I'm eyeing the Gigabyte GA-X58A-UD7, ASUS Rampage III Extreme and MSI Big Bang Xpower.
I don't need SLI support at all (1 good vid card is enough for my needs). 1 standard PCI slot would be nice, but I can work around not having one. USB 3 and SATA 6.0 isn't absolutely necessary, but would be nice to have for the future. I prefer Intel-based gigabit LAN, but I'm not stuck on it. Must have a PS2 port for my ancient keyboard that I can't live without. Would like good case fan speed control. Audio quality was originally important to me, but I now think I'm going to try using the ATI for 6-ch LPCM via HDMI to my receiver, so I probably don't need to care about onboard or discrete audio. And if I do decide I want good sound, I'd probably turn to an Auzentech.
Before the last 6 Intel-based systems, I always used ASUS but then I realized that every single one of my boards either died or developed issues after 1 to 3 years, so I switched off them. However right now I like the R3E the best, but I've heard good things about the Gigabyte... and the MSI seems very interesting. Which is the most stable and least likely to cause issues?
And are there any other premium boards I should be looking at (besides eVGA, which I don't actually like)?
Thanks!
Thanks!
