MSI AM4 pron
Discussion in 'AMD Processors' started by cageymaru, Jan 4, 2017.
  1. drescherjm
    drescherjm [H]ardForum Junkie
    13,637
    Nov 19, 2008
    Search for PCIe bifurcation.
  2. cageymaru
    cageymaru [H]ard|News
    16,687
    Apr 10, 2003
    I think someone was discussing PCIE lanes in the thread. Anyways this video says 24 lanes.
  3. Dew
    Dew 2[H]4U
    4,014
    Jun 23, 2003
    Specifically it is 24 Lanes, 16x dedicated for GPU, 4x for NVMe, 4x for Chipset.
    Now, does that mean that we will see boards with 2x8 (16 physical, 8 electrical), or 1x8 + 2x4 CPU lanes that can be repurposed for storage/networking? I would assume so.
    Considering PCIE3 is 8Gbps/lane that only gives 32Gbps (~3.8GB/sec real world) for the entire chipset.
    A 10GBe NIC is going to want 2 lanes to operate at full speed.
    Gosh, looking at what a mess this can be, I see why a PLX chip might be a popular option. Stack 32 lanes (4x 8 lane electrical) of physical slots into a shared 8 lane bus and call it a day. Let the end user figure out the best division of resources.
    Now if only bifurcation was a standard thing across all chipsets...
    Armenius and Shintai like this.
  4. Zarathustra[H]
    Zarathustra[H] Pick your own.....you deserve it.
    23,505
    Oct 29, 2000
    Hmm. Are there any good m.2 slot to PCIe slot flexible risers? Maybe one can use one of the m.2 slots for a 10GBe card.
  5. Dew
    Dew 2[H]4U
    4,014
    Jun 23, 2003
    Nope.
    There is one, but it is rated for PCIe 1 (maybe it can do 2, I dunno), and $150. http://www.hwtools.net/ExtenderBoard/P14S-P14F.html
    Sooo, worthless.
  6. Dew
    Dew 2[H]4U
    4,014
    Jun 23, 2003
    Looking at that board, I'm guessing we are looking at 2x8 (16 slot) PCIe off the CPU, the 3 x1 slots off the chipset, the bottom x16 is probably an x1 or x4, also off the chipset. The board may have intelligent switching for the 2x8 and make it 1x16 if you only have one card installed. You could then install a low-end GPU in the bottom x16 slot.
    Either way, if you were looking at all that, I'm not quite sure what the point would be in having ~9GByte/sec local reads with limited network IO. Better to sacrifice PCIe x16 down to x8 so you can put a 40Gbe NIC in there. You'll still hit nearly the same 9GB/sec.
    Ryzen, no, AFAIK. Only the forthcoming AM4 APUs will have IGPs. So those ports will be dead unless you stick an APU in there.
    Shintai likes this.
  7. Zarathustra[H]
    23,505
    Oct 29, 2000
    There is very little benefit in using RAID to stripe multiple SSD's anyway, they are already massively paralellized internally anyway.
    Going from a hard drive to any SSD is a huge improvement. Going from a slow SSD to a faster one is marginal.
    When I moved from my sata Samsung 850 Pro to a PCIe Intel 750, while the 750 certainly scores higher in drive bench tests, actual practical performance difference (boot times, load times, system responsiveness, etc) have been undetectably small.
    Besides, striping drives gains you sequential performance at the cost of seek times. Seek times are the huge reason why SSD's are such a huge improvement.
    If you have an odd workload where sequential speeds are unusually important to you, I guess striping makes sense, but for most workloads you are just giving up reliability for no benefit at all.
    Shintai likes this.
  8. drescherjm
    13,637
    Nov 19, 2008
    No they don't have a GPU. Remember Bristol Ridge and future APUs will have a GPU.
  9. JustReason
    JustReason razor1 is my Lover
    2,480
    Oct 31, 2015
    for even more clarity: A unified platform, no AM3 and FM2 but a single chipset to house both.
  10. Dew
    Dew 2[H]4U
    4,014
    Jun 23, 2003
    So you have a rather enterprisey use case, not a consumer/prosumer use case.
    It is still unclear from your description what you are looking for as far as this machine goes. Do you want local storage IO and not care about network IO? Do you want GPU IO as well?
    If we are talking about the consumer/prosumer use case, going from 500MB/sec to 5GB/sec is not going to make much of a difference unless you are slinging around large files quite often, and is going to make just about zero difference in gaming.
    drescherjm likes this.
  11. Zarathustra[H]
    23,505
    Oct 29, 2000
    Well, as I was saying, you can get great benchmark numbers, but they rarely if ever result in improvements in practical use. Your boot times, load times and system responsiveness are going to be almost exactly the same. Only time you'll ever notice is with large sequential transfers to another fast source. (RAMdisk?)
    Dew, Shintai and drescherjm like this.
  12. Namx01
    Namx01 n00bie
    46
    Feb 4, 2008
  13. dook43
    dook43 2[H]4U
    2,753
    Sep 9, 2005
    That's been made uncomfortably clear. Nobody else on this forum cares about running SQL databases in RAMdisks and wanting to move that down to RAID M.2.
    And anyone that does is certainly not purchasing AMD Ryzen at launch. What we have here is a enterprise customer on a consumer budget.
    Dew likes this.
  14. os2wiz
    os2wiz Limp Gawd
    437
    Nov 20, 2011
    A 6 core 12 thread chip is happening whether you see it or not,
    ManofGod and Kyle_Bennett like this.
  15. Nobu
    Nobu [H]ard|Gawd
    1,241
    Jun 7, 2007
    Why wouldn't they function? I'm sure they'll work fine, with an APU. Ryzen is a CPU, with no graphics capabilities, I'm 99% certain (only 1% uncertain because there is a remote possibility that they decided to turn it into an APU without saying anything). There will be APUs released later (as had been said by AMD) for the same socket. I'm not sure of chipset compatibility, but I think they should work with CPUs and APUs.
  16. drescherjm
    13,637
    Nov 19, 2008
    There are current Bristol Ridge AM4 CPUs that should function with the video ports. Next year there will be Zen based APUs that will use the video ports as well. The Zen parts released in Q1 will not use the video.
    MRFSYS likes this.
  17. WhoBeDaPlaya
    WhoBeDaPlaya 2[H]4U
    2,387
    Dec 16, 2002
    A few years back, some folks at work were crowing about these new-fangled mechanical keyboards.
    I brought in the OG and shut 'em up :)
    [​IMG]
    Mint condition with the original box, except the rubber on the cable has started to disintegrate :(
    Bought it way back when for use with an IBM Thinkpad 760ED when it launched.
  18. Zarathustra[H]
    23,505
    Oct 29, 2000
    Nice! A twin to mine!
    I'm impressed your keycaps are still good after all that time!
    I've often thought about bringing a buckling spring keyboard to work, but I worry that I will annoy my colleagues, since we work in an open office environment. I don't even have cubicle walls :p
    WhoBeDaPlaya likes this.
  19. os2wiz
    os2wiz Limp Gawd
    437
    Nov 20, 2011
    I think you should wait to see the Asus ROG board for Ryzen. It has not been announced but is likely to have a PLX chip on board and more options than the other x370 boards.
    MRFSYS likes this.
  20. ManofGod
    ManofGod [H]ardForum Junkie
    8,415
    Oct 4, 2007
    For me, as long as I can run my 2 x Sapphire R9 Furies, any good X370 board will be fine. B350 is all I will need for my work computer though.
  21. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    5,172
    Jul 29, 2009
    I'm hoping that most/all AM4 X370 are really good dependable boards. Last time around you had several AM3+ which could run certain cpu but had poor VRM or overclocking stability.
    I'm guessing that if the GDC leak is true the end of February beginning of March would see reviews with the release a week later ?
  22. Harney
    Harney n00bie
    3
    Dec 14, 2016
    A bit late to the party but i use those and a fair few others in the audio production scene ...without legacy pci slots i would be using pc's from say 5 + years ago or i would have to upgrade both of my pci sound cards to pci-e and this would cost me well over a grand to do so ...so thank the gods for legacy pci and sintech adaptors if i have to use a board without any lagecy slots
    https://www.amazon.co.uk/Sintech-PC...d=1492600523&sr=1-2&keywords=PCI-E+express+X1
    more info if interested
    https://www.gearslutz.com/board/music-computers/811773-legacy-pci-support-new-mobos-doubt-5.html
    https://www.gearslutz.com/board/mus...use-pci-card-pci-e-only-machine-solution.html
    jahsoul likes this.
  23. jahsoul
    jahsoul Gawd
    581
    Feb 3, 2011
    I said that a little while ago on another thread. Legacy PCI are a God-send for those of us who are still using supported PCI sound cards (and mine dates back to 98 - Ensoniq Paris). I'm currently running a P6X58 Premium/X5675 combo, but really looking at getting an AM4 setup for the legacy PCI.
  24. dave343
    dave343 [H]ard|Gawd
    1,519
    Oct 17, 2000
    That's never a good sign... so either they are afraid of what big reviewers like yourself might have to say about their boards, or they just want out of the north american market I guess. Back in the mid 2000's at a store I worked at, we sold quite a few ASRock boards, they were feature packed, and pretty stable when OC'ing with. They seem to still be feature packed, but maybe the quality has gone down and they don't want reviewers looking too deep into them...?
  25. noko
    noko 2[H]4U
    3,338
    Apr 14, 2010
    Well the Tachi looks to be very high quality, AsRock should have shipped out the first one to HardOCP for testing and to show.
  26. Pieter3dnow
    5,172
    Jul 29, 2009
    The bad part is if you see which people they shipped it to that are on youtube, seems that it is not that important any more for ASrock to be on here , giving up is not the best thing to do.
    So I googled and found this link on Anandtech and it made me smile https://forums.anandtech.com/threads/asrock-taichi-x370-review.2501149/
    Check the comment on below it ;) .
    or from Tom's http://www.tomshardware.com/reviews/asrock-x370-taichi-amd-ryzen-am4-atx-motherboard,4967-3.html
    Then you stop wondering why ASrock does not want to ship review samples to [H]ardocp ..
  27. noko
    noko 2[H]4U
    3,338
    Apr 14, 2010
    lol.
    YouTube videos are getting to the point I rather just stick my fingers down my throat at times, I can barely watch any of them all the way through. The actual hands on (no pun intended here) that show how to do something, faster pace, less talk are very useful. Anyone just talking in front of the camera is 99% of the time worthless as well as pointless.
