Is there any way too force more voltage then 100mV with MSI AB?
Read that you can change it both in .cfg and target on the icon, but that wont work anymore.
I tried the old .cfg trick but it didn't seem to work with new NV drivers. it wasn't for my system so I didn't worry too much. you might want to check on their forum too.
Just because you can unlock the slider doesn't mean it will actually apply the voltage shown. Newer video cards have a hard cap in the BIOS to how high the voltage can go, so you need an unlocked BIOS to go with it. If you have a Pascal card then you're SOL.
