1602 on core., only have taken memory to 3800mhz. 65c with fans max.
runs rock stable. some games it hits power limits and down clocks to 1586.
one hell of a card. wish nvidia wouldn't have these stupid limiters.
What are your settings in Afterburner?
Really? Where are these 970 cards that clock that high? I have not seen a single one get anywhere near that. Not mention there are only a couple cards that have enough TDP room for that to even theoretically be possible.Damn that's really impressive for a card on air cooling. It's also impressive because it's a GTX 980. I have looked around and 1600mhz is super rare. The 970s seem to get to 1600mhz way more often. Cheers man.
Enjoy that beast.
Enjoy that beast.
No that is not how it always is. The 970 has much lower power cap in many cases so it cant oc higher than the 980. And what he claimed is not true at all anyway from the dozens of reviews I have looked at. These Maxwell overclocks come down the bios and tdp for the cards. Many of the non reference cards are power hogs too and not even the reference cards are as efficient as Nvidia claims.that's how it always is. the more shaders, the lower the clocks (within the same architecture.)
Well I dont want to look through 11 pages. Going by official reviews I have not seen a single 970 hit 1600 much less maintain it. In fact I would say the average 970 does about 1450 before hitting TDP limit. Heck my 970 was throttling at 1400. The MSI gaming cards are about as good as it gets and have a BIOS that allows much more headroom and even that could only do 1542 in the review here.
Fans are so quiet at 100% 1576mhz in sli here.
Enjoy that beast.
I have a hard time believing he maintains 1576 on one gpu much less two.can you post your firestrike results here please at 1576 in SLI
The differences between the GTX 970 and GTX 980 are in the GPU - not anywhere else. (In other words, the GTX 970 is a gimped GTX 980.) Therefore, how held back a given game is BY that gimping depends on the game - not anything else. While for some games with a given GPU, you will need more CPU; with others, tag-teaming a GTX 970 with as little as PentiumG3258 is enough for maxed-out 1080p. It is also likely that some of those firewalled@1080p titles can do DSRed 3K (1.5x screen resolution of 1920x1080) if not DSRed 4K (3840x2160) with the same G3258. That is a $600USD upgrade for any desktop with a 600W PSU of decent quality (CPU, GPU, motherboard, memory) if you live near a MicroCenter (and marginally more if you are limited to e-tail - primarily due to CPU costs).
Yes - I get the economy biteth - however, it's still doable - and doable-on-the-relatively-cheap compared to just twelve months ago. The biggest issue is GPU inventory.
i got two coming tomorrow
What can i expect to get in SLI for an overclock ? I am thinking around 1450 core fans on auto
I dont plan on running my fans 100 percent or a custom fan profile
Mostly accurate. Depending on the manufacturer and what liberties they've taken on the design of the GTX 970 some are limited by the TDP and power distribution Chips on the PCB of the actual card. Some others have not done any limitations there and have only done limitations in the firmware of the card to keep the GTX 970 at 145 Watts vs the 980 at 165 watts. In those cases you can modify the actual bios now that this is doable.
See Nvidia's info on the power delivery system that is lacking on the reference suggestions from them http://www.hardocp.com/image.html?image=MTQxMTA2MzcyNDBjUEVEMXNuZnBfNV82X2wuZ2lm. Some manufacturers didn't do this though as mentioned before so it's good to see which 970 has the feature set you want before buying.
Still, that is easily the lowest price for a FTB upgrade (full-tilt-boogie) - and the GPU is over half the cost. The ONLY assumptions I am making are the following:
1. The target case will hold all of the new components. (Basically, either mid-tower or full-tower.)
2. You already have a proper PSU; however, even if you don't, unless you get overly pricey, it will add - at worst - $100USD to that cost.
3. Drives and OS will remain unchanged - a safe bet unless you are running Windows Vista or earlier.
I dragged in the G3258 because of various bundles (especially that of MicroCenter) and some curiousity as to how hobbling it actually is with this GPU. Depending on the game, it hardly is. While there may be some QA/QC issues for certain manufacturers, it is still general availability that is the biggest issue.
