MSI 780ti SLI dilemma
Drew1966
I just dropped a second MSI 780ti into my new Asus VI Formula with a 4770. I loaded Far Cry 3 last night and the game reads up to 95FPS with Fraps, but the image is gameplay is incredibly choppy even with the high framerate. I have an old Dell 3008 WFP. I know all of my drivers are updated and SLI is enabled. I'm wondering if it's not my monitor producing the stuttering effect?
tylertoast
Artifacting maybe?
I doubt it would be the monitors issue. I've never had that happen to me.
Try maybe an older GPU if you have one lying around see if you still have that same issue. Afterwards if the issue persist you could replace the monitor.
Whats the model number of the Monitor?
Drew1966
Artifacting maybe?
Dell W3008WFP it's 1440p and the funny thing was when I had one 780ti in, it ran smoother, but recorded less fps it averaged around 47-71 or so. But with two cards in the FPS ranged high 70's-to mid 90's, so I'm totally confused. Granted I only had around an hour or so to fool around with it as I just finished redoing the water-loop on it late last night.
cybereality
Have you tried any other games? Maybe it's just a glitch w/ the FC3 SLI profile.
Drew1966
No just Far Cry 3, and 3mark Firestrike run, which kept giving me a windows error something about windows resolution change caused an error so the test couldn't be completed.
cybereality
Maybe something is wrong with one of the cards. You should test them individually.
257Tony
Fc3 has had multi gpu stuttering issues forever. Turn off the in game vsync and set a frame limiter at 60 with afterburner or similar program. Should help a bunch, although you may have to deal with some tearing
Drew1966
I went home last night and turned v-sync on and the stuttering went down considerably. That's all the time I had to test last night. I still have to figure out the error in 3D Mark.
Bluesun311
I was going to suggest Afterburner, as well. I think it will help just to have it installed for GPU sync. Also you might want to do a free install of drivers. I have issues with the recent beta and rolled back to the last WQHD to fix them. (Old games)
