MS Edge crashes if it's left open
Discussion in 'Operating Systems' started by nilepez, Jun 17, 2019.
  1. nilepez
    nilepez [H]ardForum Junkie
    11,483
    Jan 21, 2005
    Anyone else find that if you leave edge open for several days (maybe a week), it crashes? I think it happens when my PC goes to sleep or is woken up, but I'm not sure.
    Please, don't say use another browser. This isn't my primary browser, but I keep a few things open in it in a private window (as well as run FB in a non-private browser). Everything else is in waterfox.
    Just wonder if this is a known issue or if anyone has a fix for it. I find it annoying to have to log back into the pages ever few days.
  2. polonyc2
    polonyc2 [H]ard as it Gets
    16,895
    Oct 25, 2004
    I've never left Edge open for days so I don't know about that specific issue...but you can always go into the settings and have Edge open up each time with your previous Tabs
    auntjemima and pendragon1 like this.
  3. B00nie
    B00nie [H]ardness Supreme
    7,980
    Nov 1, 2012
    You should not open Edge at all let alone leave it open.
  4. Algrim
    Algrim [H]ard|Gawd
    1,538
    Jun 1, 2016
    Why so? It's moving, if not already moved, to the Chromium code base so not much different than running Chrome (substitute Microsoft spying vs. Google spying).
  5. auntjemima
    auntjemima [H]ardness Supreme
    5,159
    Mar 1, 2014
    He hates everything Microsoft without even knowing a lick about the software he's talking about. Not worth the hassle.
  6. pendragon1
    pendragon1 [H]ardForum Junkie
    14,229
    Oct 7, 2000
    what auntj said and no not yet. you still have to download the chromium based edge, its not automatic. still beta(at best) iirc.
    B00nie likes this.
  7. GoldenTiger
    GoldenTiger [H]ard as it Gets
    18,871
    Dec 2, 2004
    Yep. Big time Linux fanatical zealot.
    pendragon1 likes this.
  8. B00nie
    7,980
    Nov 1, 2012
    So you're actually claiming Edge is a good browser worth using? ROOOOFL! Get a grip.
  9. auntjemima
    5,159
    Mar 1, 2014
    You and I both know that wasn't the point of my comment. Keep acting like anything you say is worthwhile.
    GoldenTiger and pendragon1 like this.
  10. modi123
    modi123 [H]ardness Supreme
    5,501
    Sep 6, 2006
    Anything in the 'Event Viewer' right after a crash?
    I keep a handful of browsers open for days on end, and haven't noticed Edge being any worse than Chrome or FF in stability.
  11. nilepez
    11,483
    Jan 21, 2005
    I don't see anything on the 16th or 17th. I do see errors for Edge and claims that it terminated the program, but I can't tell if it's a point where it actually shut down (I didn't think to check when it happened, but I see one for the 18th and AFAIK, it didn't crash then.
    It also says to look at Security maintenance control panel, but I'm unclear what I"m looking for there...perhaps it's because it says Edge/windows quit interacting? Next time it crashes I'll check the event browser and see if I see anything of use
