fightingfi
- Oct 9, 2008
"Once you upgrade and activate Windows for the first time, you can perform subsequent clean installs without having to track down your product key."
Never had to track down my product key because it is stored with the install media.
"In Windows 10, your PC's activation status is stored in the cloud, so once you've activated Windows 10 for the first time, you won't have to worry about it ever again."
Until their "cloud" crashes and then you are fucked.
if you need to reinstall at 30k feet then I'd say you have bigger issues than net connectivity.
There are guys who do have to travel a LOT for their jobs.
...it installs and operates unactivated for an amount of time. It does not have to OH MY GOD ACTIVATE RIGHT THIS SECOND OR I'M CRASHING THIS PLANE.Well, what happens if you are offline. Like at 30,000 feet and you don't want to pay the ripoff prices for in-plane WiFi? Or you are on an Amtrak train that goes into a tunnel?
And install W10 at the same time?
Gah, then never mind; over the past few years, we're batting about .600 in working on systems that don't have the key labeled properly or are torn/illegible.Keep in mind that OEM (System Builder) versions do use a key. Not sure how these versions do a reload after they are activated, ie. if you still need to put the key in or not. (likely you will)
