MPC-BE and integrated graphics
Seeker30
Hello, hopefully a simple question.
New PC might be a Win10 with an i3-8100 or possibly an i5-8400. No discrete graphics card, only the integrated graphics capabilities.
Is this good enough to run MPC-BE's "stock" or "default" renderers/pixel shaders? Specifically VMR9(renderless) and the shaders Sharpen, Sharpen Complex 2, and 16-235 to 0-2555(SD/HD), used either pre or post resizing. At 1080p.
Or does it depend on the motherboard as well as the CPU?
I can't seem to finds a clear answer online. I have read enough posts to know that some shaders such as MadVR would be a no-go for IG, but can't seem to find a simple answer as to whether IG is enough for the "normal" pixel shaders that come pre-packaged.
