Napoleon
- Jan 27, 2003
Hi All-
I currently have a rather involved external setup ( 2 heatercores immersed in a 55 gallon blue drum filled partially with water) and am thinking of moving to an internal setup.
Currently only the CPU (hot X58 Xeon) is under water, but there's a good possibility that I'd put my prospective OC'd 1080ti under water as well.
My thought is 4x fans with push only setup and 2x 280mm of this radiatorHardware Labs Nemesis 280 GTS X-Flow Radiator Review . Has anyone use this radiator before? Any pros/cons? I like it for its low restriction/low profile nature
Based on their review it seems that 2x these radiators even with low RPM fans will move a TON of watts, but I'm not sure how this translates to actual CPU performance
Case: Corsair 750D Airflow
Pump: MCP655
CPU block: Heakiller 3.0 LT
Fans: Not sure - Noctua PWM? I think the stock 140mm's in the 750D don't have enough static pressure for a push only setup but I could be wrong
Thanks for your thoughts!
By the way, I like overkill setups, this is a hobby for me. If I wanted efficiency I'd pick up an AIO and be done with it
Pump: MCP655
