Temps are from speedfan. Ive checked this case 3 times.. all fans are on high setting but the bottom fans blow so little air I can see why the cooling is so bad on this case.. either way I shipped it back and put my cosmos in and my ambient went down 10c.
If this is the case, there's something wrong with the fans. There's no reason the fans should be blowing that little air. I have mine on LOW because I don't even need them on HIGH to have great cooling. Even on low, the 180mm fans push a noticeable amount of air. The RV02 is tied with the Lian Li PC-B70 as the best aircooling case I've used yet. I'd look into getting Silverstone to replace the fans before giving up on this case - it's a great case.
