do you just highlight the folders and choose copy?
Originally posted by Bunk454
To further the discussion on his original question, would the battery life being saved here warrant the extra hassle of having to rip the DVD to your HD?
Originally posted by viper11885
If possible, it would be best to rip the dvd onto your hard drive prior to using the battery. So if you are somewhere where there is a AC jack available, just use your power adapter and copy the movie onto your hard drive. Therefore, you won't have to waste any battery power ripping the cd to hard drive or running the dvd directly from cd drive.
w00t!Originally posted by mamiyarz67
I use DvdDecrypter , takes about 20 min on my 2.6hgz @ ~5x.. then Power DVD can open the "Dvd on hard disk" and your rockin... pretty easy! 200 gig externals rule
