Mountain Mods U2-UFO White and Clear
cabanaboy38
I have included the horizon brace and security flange along with fan grills wheels and all screws. U2-UFO CYO (Crystal Ship Style - Custom Computer Case)[U2UFOCSCYO]Enter Mountain Mods Crystal Ship series.The Crystal Ship incorporates the lightweight yet extremely durable U2-UFO Hyper Modular Frame with beautiful laser cut acrylic. The Acrylic is 1/4 inch thick cast. The back panel, motherboard tray, bottom panel, struts and 5.25 bays are all constructed from high grade aluminum and powder coated mirror black. The contrast of the 1/4 inch thick acrylic(Front panel only)Sides and top are 1/8 thick clear acrylic on the White frame is stunning! The "Hybrid" combination gives you the best of both worlds; an extremely sturdy frame with the full viewing capability of an all acrylic case. It also makes this 1/2 the weight of an all acrylic case of the same size.WORLDS ONLY HYPER MODULAR COMPUTER CASE Choose your own Adventure!The U2-UFO is the ultimate in computer case experience. Coming in at 18 inches cubed this box can hold just about anything and everything your heart could desire in a computer case. They can house up to 5 x 5.25 devices and up to a whopping 18 hard drives using Mountain Mods 120mm Fan Hard Drive brackets. Whether you are cooling with air, water, or phase changing solutions this is the case that can do it all. Not only does the U2-UFO have space to hold your high end components but with the high volume of air flowing in and out of the case it will keep them operating at cooler temperatures resulting in longer life and better performance. The U2-UFO is fabricated by skilled workers in the USA. It is made from thick aluminum making it lightweight, sturdy, and thermally friendly. Casters are included for easy mobility.Discover space in a U2-UFO.Assembly INSTRUCTIONS Specifications:Material - Aluminum 5052 / cast acrylic Thickness - 1.65mm-3.25mm / .25 inches Dimensions - 18x18x18 inches Empty Weight - 24 lbs.See additional PICS for panel details.
http://www.ebay.com/itm/251293632440?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
