Motherboard rejects power supply?
Discussion in 'Power Supplies' started by branana, Mar 25, 2006.
  1. branana
    branana Limp Gawd
    277
    Apr 10, 2004
    I have had a Antec SmartBlue 350W power supply for about 3.5 years now. It always worked fine. Perhaps not the quietest. I have opened it up and replaced one of the fans with a quieter one and hooked up both to a fan controller.
    The problems started about 2 months ago. It's off and on. Basically, after extended periods of being unplugged (the switch in the back of the PS off), the computer will not power up. Sometimes it does power on but no POST, the fans just whirl at like half speed or something. This began to happen sporadically. The solution was just to leave it plugged in, switched on, and after maybe an hour, it would boot. Once booted, the computer runs fine through intensive gaming+video encoding what not.
    This morning, I shutdown the computer normally via OS command, and it refused to power up again.
    I tried a different power supply (no name 350w), system boots. I tried the Antec in another system, that other system boots. But the Antec will NOT power up my system anymore.
    Is this because the quality of the rails have degraded over time on my Antec and now the motherboard deems the voltages too far off from normal voltages?
    I have a Gigabyte GA-K8NS Ultra-939 motherboard. 2 hard drives, nVidia 6800GT and other ordinary components.
    Any suggestions would be great! Thanks for reading.
  2. Bbq
    Bbq King of Charts
    12,272
    Feb 21, 2006
    I don't think it's getting enough power. Did you add any hardware to it recently?
  3. branana
    branana Limp Gawd
    277
    Apr 10, 2004
    No, have been using the same configuration for years now.
  4. Bbq
    Bbq King of Charts
    12,272
    Feb 21, 2006
    Did you OC recently?
    I seriously think it's that the pered su isn't providing enough juice.
    The Antec you used is probubly running at load at all times, which isn't good, and causes eventual failure. I suggest a new psu. There's a few stickies at the top, and that will help you choose.
  5. 2gigs
    2gigs [H]ard|Gawd
    1,200
    Dec 4, 2005
    Go try another psu, a cheapo one if you have to
    see what happens
  6. branana
    branana Limp Gawd
    277
    Apr 10, 2004
    Got a Fortron Sparkle 400watt ps for $37.99 CAD, works like a charm now. Guess the Antec was degrading and eventually couldn't provide enough juice.
