Child of Wonder
- May 22, 2006
Would anyone have a recommendation for a motherboard to use on a ZFS file server? After over a month of struggling, I'm finding the ASUS M4A89GTD PRO/USB3 is not the solution. I'm using an IBM BR10i flashed with IT firmware, a cheap Syba card just to give me 4 more SATA ports, an Intel quad port PCI-E NIC, and an Intel Gb PCI NIC but this is apparently too much for the board to handle and I frequently get "insufficient runtime space for MPS data" errors which I've found essentially means I have too many add-on cards.
If I remove some of the cards and boot only with the BR10i and Intel quad port NIC, I can make it past the BIOS splash screen but then the system simply reboots itself. Memory tests OK and I've tried two different Corsair PSUs (HX620 and AX850) with the same results.
I'd prefer AMD but would switch to Intel for the right board. I need something that will take the IBM BR10i card, Intel quad port NIC, and Syba controller. It needs an eSATA port and onboard video so I'm not wasting a PCI-E slot on a GPU. I'll be installing Nexenta Community Edition or Openindiana + Napp-It.
