Skylinestar
- Jun 14, 2011
I'm using Biostar TPower i45 motherboard, which has the Realtek ALC888S audio.
Recently, the motherboard rear audio port (green stereo out) is giving me distortion in music playback. The distortion sounds as if the speakers are playing out very loud and distort due to clipping.
When the speaker is plugged to the front audio port on my casing, the distortion is gone. Everything sounds normal. No distortion.
It is not the speaker problem as I've never had the issue in the past. The speaker also works fine when plugged to my iPhone.
Is my rear audio port faulty? Is there a quick fix?
