Motherboard for 3 GPUs. Can I use what I have?
wild thing
I have 3, 3080s. Don't believe I will be getting more. I have these motherboards.
Can I use what I have to put all 3 GPU's on one MB? Or should I invest in a better MB?
MSI X99A SLI PLUS LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard https://www.newegg.com/p/N82E16813144100
GA-Z170X-Gaming GT https://www.gigabyte.com/us/Motherboard/GA-Z170X-Gaming-GT-rev-10/sp#sp
MSI Z590 Pro WIFI6 that is running one of the 3080s.
asus strix b560-g with built-in wifi running one of the 3080s.
MSI - i7 5930k
GA-Z170X - i5 6600K
asus strix b560-g i7-11700KF
PSU - CORSAIR HX Series HX1000 CP-9020139-NA 1000W ATX12V v2.4 / EPS12V 2.92 80 PLUS PLATINUM (3 years old)
Thanks.
legcramp
You can use any of those tbh assuming you're using risers with them too.
I took a look at the MSI board, and noticed that it has 4 PCIe X16 slots. That's rare; most boards have two max. You should be able to drop your three cards into this board and use them directly. If that doesn't work, you also have two X1 slots. You can plug one card into an X16 slot, and plug the remaining two into the X1 slots, using riser cables. These cables are available through Amazon, typically about $10 each, maybe less if you shop around. So the first board, the MSI board, should work fine for you. I didn't check the second. Hope that helps - Charlie
