Blackstone
- Mar 8, 2007
what is the most rock solid brand for a dual gtx980 setup? 850 watts minimum.
Depends on the OEM not the brand. Corsair has something like 3 or 4 different companies making PSU's for them and some are great and some are not. My EVGA G2 is made by Superflower and is superb. The previous Supernova line not so much.
Like mentioned above, read reviews here and Johnny Guru and make your choice based off their findings.
Although...
JG gave my Corsair RM 850 power supply a 92% or something like that, so I bought it. Nice looking silent single rail unit, which I prefer to multi-rail.
I'd found it on a good deal and popped over there to quickly check it out and based on that, pulled the trigger.
Few days later, I saw that the H had reviewed the unit some time ago and gave it fail and declined to recommend it so...
If u have time, check out a few places.
Although...
Although...
Any problems with it? Might just be the review unit H had.
Read my post above.
though [H] reviews are on par with them, something I bet OklahomaWolf would acknowledge
It can clearly be seen by the fact that JonnyGuru's RM850 ambient hot testing only reached 40 C, while [H]OCP ambient tests at 45 C.
I've had units pass 50 C. It depends on the unit being tested, the ambient temp of the room, and how many extra fans I have running in the hot box. Most of the time it has to be a big unit for the box to get that hot.
For the most part though, the area between 40-50 is plenty good enough IMO to see if a PSU is worth it.
