After 6 weeks of owning my 2600k and gigabyte z68a-d3h-b3 combo, ill just man up and say it... I didn't spend enough time researching before I purchased.
I've been overclocking for years and years now and I guess I took my leet skills for granted.
Since I assembled this system i've been pushing the overclock, tweaking voltages, benching, priming, burning, gaming, and logging. Settled on 46x10 with around 1.38vcore at full load, with HT on.
Overall I was disappointed with the overclock, as the chip seems willing to boot into windows @ 50x100, but I could never get it stable under load...in the end I just chalked it up to a crappy motherboard, as far as oc'ing is concerned at least.
Well, believe I was right, but as of this afternoon I realize it was because of a potentially dangerous combination of ignorance on my part.
After noticing some bizarre behavior with programs like intel burntest and prime95 ~ cpu would ramp up to 46x100 and temps would shoot up to around 70-75c.....and then about every 15 to 20 seconds, the temps would all drop about 10-15c suddenly, and then a few seconds later be back around 70-75c. Seemed very odd to me.
This afternoon while benching I noticed that the temperature drop always occurred everytime my TDC got into the 125w range....it would stay there for a second or two, then drop to 75w or so, and then start climbing back up. Oddly, none of my monitoring programs showed my multiplier dropping during this...but it certainly could be noticed in Intel burn test, as the gflops and time to complete each cycle could vary considerably when this would happen. So I got to poking around on the net a bit more, and came across
this thread.
First of all, my motherboard is rated @ 95w max TDC. A stock clocked i7 2600k is rated at 95w. I had NO intention of maintaining stock clocks. I completely overlooked those "little" facts. All I saw was that I could change those limits in the bios and figured YEEHAW, put the voltage to it and see how fast it goes. In its current configuration I have seen my 2600k hit 130w before being throttled back. Now the throttling is where I became a little concerned when I realized what was happening. At those power consumption levels my mosfets are pegging out at what is apparently their maximum temperature ~ 66c (150f) , and apparently when they get to that temperature they geek out..had I continued to abuse them I would imagine it was only a matter of time before they melted right off the board.
As I am beginning to understand, my VRM's are on a 4+1+1 phase ~ and not only does that cause the horrible vdroop this board exibits, that style phase will heat up tremendously faster ~ and not to mention the factory "heatsink" draped across them looks like something from a lego kit, and feels like it is attached with unicorn turds.
So now I am not exactly sure where to go from here. First order of business is to try and get my mosfet temperatures under control, assuming that is even possible with the amount of wattage I am drawing with my cpu overclock. Other than that I guess I need to lower my oc. I suppose really my only legitimate option is to buy a motherboard that is actually designed for what I am trying to do, overclock the piss out of it.
If any of my information is incorrect, please help correct me. I am just coming to start to realize the pieces of the puzzle I was missing when it comes to overclocking a sandy bridge.
Hopefully this information catches someone before they nuke a motherboard doing dumb shit like I was.
this thread.
