Greetings all,
I would like your opinion on the wallmounts you got from monoprice. I just picked up the Low Profile Wall Mount Bracket for LCD Plasma (Max 165Lbs, 37~63inch) for my Westinghouse TX 42". This is going to be a really budget HTPC setup! Cheap 1080p TV, cheap wallmount, cheap PC speakers (Logitech Z-5500s), sweet!
So, I plan on wallmounting it at my apartment. I'm not sure if my lease allows it or not, but I'm sure I can hide the screw holes with some drywall patching stuff. Ideally, i'd like to run the wiring inside the wall, but that's too much of a hassle, so I ended up picking up some Wiremold CordMate II plastic channels.
The reason I chose this instead of the thicker hometheater one is because my the Westinghosue TX is not flat on the back, it has a 'hump' in the middle for the 100 x 100 VESA mount. (I'm also somewhat sad that the TX isn't flat on the back with giant spaced mount holes like other TVs of this size, 100mm just seems weak!) I will end up using two plastic channels, one on the left, and one on the right. This would also help seperate the power cable from the HDMI cable and stuff.
Anyhow, back to my question, how is the quality of the monoprice mounts? Does it have any security features to prevent theft?
In regards to the screen height, is ideal being eye level (while sitting on the couch) on the bottom third of the screen? Do you folk who got the flat mount ever wished you had a tilt mount?
That's about it for now! I'll post pics up in about a week or two when I move down.
