I've got a Mitsubishi WS-65315 TV. It's a 65" widescreen HDTV.
The rear panel has all the S-video and RCA jacks for hooking up stuff and component inputs for my Xbox, progressive scan DVD player, and HD-PVR box from my cable company (Adelphia).
There is also an input labeled MonitorLink/DVI along with a serial port labeled MonitorLink Control RS-232C.
In the manual it states about the MonitorLink/DVI:
I have a PC with an ATI All in Wonder. It has DVI out on it. When I first saw the input on the TV I was hoping I could hook it up directly. Is there a way to do it through that DVI input on the TV? If not, how can I utilize the 1080i capability of the TV? I can use the S-video out from the AIW, but that seems like a waste when the TV is capable of so much more.
Sorry about the long post with all the quotes from the manual.
"This is a Mitsubishi-exclusive proprietary digital interface for the display of high quality digital video signals from Mitsubishi products such as the HD-500 HDTV Receiver/Controller. All video signals, both analog and digital are sent digitally to your Mitsubishi TV. Can also be used as a DVI (HDCP input for other compatible sources."
"Note: The DVI-HDTV input terminal is compliant with the EIA-861 standard. It is not intended for use with personal computers or devices outputting video signals with computer resolution."
