Monitor sitting in snow. How long until I can turn it on?
Discussion in 'Displays' started by DaneGuy, Feb 15, 2007.
  1. DaneGuy
    DaneGuy n00b
    49
    Feb 7, 2007
    My Sony FW900 (HP) is being delivered today. It will be left by my garage until I get home. The temp is currently 16 degrees. How long should I wait before turning it on?
    Thanks!
  2. Gamefreak99
    Gamefreak99 [H]Lite
    68
    Apr 18, 2004
    Interesting question :)
    Personally, and I'm not sure if this is "correct," but I'd take it out of the packaging and just let it sit until it was room temperature. But you may be fine plugging it in right away, hard to tell. Just feel how cold it is and use your best judgement :)
  3. young wing
    young wing 2[H]4U
    2,552
    Jan 21, 2007
    Id let it sit outside the box for about an hour. I did this with speakers once, I did not want to blast them whilst being cold. Same principle.
  4. Blauman
    Blauman [H]ard|Gawd
    1,550
    Jul 27, 2004
    make sure that no condensation forms on the display, its not likely but cant hurt to make sure it does not happen.
  5. GameDad
    GameDad [H]ard|Gawd
    1,570
    Oct 12, 2005
    mostly correct, it would depend on how long it will be sitting in the snow, if more than a couple of hours, i would bring it in and unpack it, and let it sit overnight unplugged, if you cannot wait that long, take a look at any of the metallic parts and the screen for frost, let them warm naturally and evaporate the condensation (probably 3-4 hours). Waiting overnight ensures that condensation on the circuit boards internally is entirely evaporated, and not just melted and waiting to short circuit something.
  6. Voltron
    Voltron Limp Gawd
    137
    Mar 9, 2006
    Since it's a LCD I wouldn't worry about it to much. If you can let it get room temp, that would be good. But starting it up earlier wont hurt it either.
    If it was a CRT, I would say let it warm up for sure before starting it up. Just because that sudden start on a cold tube might not have a good effect.
  7. Snowdog
    Snowdog [H]ardForum Junkie
    9,236
    Apr 22, 2006
    I would not take it out of its packaging, as condensation would happen very fast. If it is wrapped in plastic, inside, I would remove outer packaging to help it warm quicker without exposing to moisture.
    You want to warm up without being exposed to warm moist indoor air. Cold electronics + indoor air = wet electronics = not good.
    I would wait several hours until unwrapping, just to be safe, especially on something that has very limited warranty options.
    Whenever I use my digital cameras in the winter I always put them in a plastic bag and keep them wrapped for an hour or so when I bring them back inside. But they are much smaller and warm quicker.
  8. DaneGuy
    DaneGuy n00b
    49
    Feb 7, 2007
    Thanks for the great responses. So, I guess 10 minutes isn't long enough. :p :p
    I'll just stare at it in the packaging for a few hours. :)
  9. Blauman
    Blauman [H]ard|Gawd
    1,550
    Jul 27, 2004
    not be a pain but the FW900 is a CRT, a 24" CRT to be exact.
  10. ipam45
    ipam45 Gawd
    566
    Jul 14, 2006
    i would have a little ceremony of using your current monitor for the last time :D
    i think it would be okay but i rather be safe than sorry!!!
    also...it should tell you the operatable tempertures in the manual or something
