Ok, so not quite money no object, but I'm trying to build a decent system that will play decently at 4k.
Parts for the core build includes:
Case: Thermaltake Core P5 ATX Open Frame
PS: SeaSonic Snow Silent-1050
MB: Asus Maximus VIII Hero
CPU: i7-6700K
RAM: G.SKILL TridentZ 2 x 16GB DDR4 3200 14-14-14
SSD: Samsung 950 PRO 512GB
SLI: 2 x GTX980TI-DC3OC-6GD5-GAMING
NIC: Intel X520
Monitor: Samsung UN48JS9000
For the loop, I have the following inbound:
Radiator: XSPC AX480 (white to match the Snow Silent)
Fans: Thermaltake Riing 12 Series Red
Pump / Reservoir: EK-XRES-140-REVO-D5-PWM
MB Plate: EK-FB-M8G-MONO-NK
Strix Plates: EK-FC-GTX980-TI-STRIX-NP
Strix Back Plate: EK-FC-980TISTRIX-NK-BP (just a single since I'm SLI'ing)
Dual Parallel Block: EK-FC-TERMINAL-DUAL-PAR-3SLOT-PX
Compression Fittings: EK-ACF1013-RD
Tubing: PrimoFlex Crystal Clear
Coolant: EKOOLANT-EVO-1000-RD (2l)
So the plan is the loop will go:
Radiator -> CPU -> GPUs -> Reservoir/Pump
I plan to connect the water pump to the fan header designated for that purpose on the Hero.
I got the base system assembled and it looks like this so far:
And I got the first 980Ti and it looks pretty decent I think:
So do you guys think I'm on the right path, or would you do anything different?
I'd like to hit 4.7 or 4.8 on the Skylake and 1500 on the 980Ti's.
I plan to convert to hardlines once I get everything working to my liking with tubes. Also got misc other parts ordered not listed above, like a T and a ball valve and a temp sensor.
Before I go much further, I need to clean my office. lol
CPU: i7-6700K
NIC: Intel X520
