I have an ABS Canyon 595 case, which has one of these fan controllers built in. As you can see on that page, it's supposed to drop a 1200 RPM fan to around 720 on the lowest setting, but for some reason my Scythe Slipstreams are running between 900 and 1000 RPM. On the highest setting it runs the 1200 RPM Slipstreams at 1250 to 1400 RPM, which is a bit odd...
I'm kinda wondering why the fans are running so fast, and also if there's a simple way to drop the speed a bit. I don't have a soldering iron or any experience using one, so that's out. Could anything be done with the 4 pin molex power input?
