The last time I used onboard audio was back in around 99 with my P3 and CA810E (yeah, I know)... Anyway, it was BAD!
So, for all my systems since then, I've just been using the same SB Audigy Platinum... My question is, how has onboard audio progressed? It used to buzz and click when you moved the mouse and did stuff. Does it still do that? My SB Audigy Platinum is getting dated, and with the audio controls now located on teh front of new cases, is it worth it to continue using the Audigy? Is it worth upgrading to an Audigy 2? Or is onboard good enough to try?
My system is connected to a Panasonic home theater (components) system with 4 satelites, a center channel, and a sub. Unfortuantly it's Dolby Pro Logic. If that matters, any.
