Is this possible? Due to the layout of machines and incoming cables in my house I would like to connect the modem directly to a switch and then run a long cable to a wireless router centrally located inside my house. None of the other LAN ports would be used on the router, but the switch is going to have all 4 ports (Plus the 5th for the incoming modem) used.
As it is setup now, I can't see the internet from the wireless laptops. My laptop CAN see the other two networked computers but can only access one of them.
I'm currently connecting a port on the switch to port 1 on the router, not the 'internet' port. Either way didn't seem to make a difference.
I reset all the devices powering on the modem first, then the switch, then the router.
Help!
Help!
