mixing ram CAS speeds
Discussion in 'Memory' started by Cataulin, Jun 28, 2016.
  1. Cataulin
    Cataulin [H]ard|Gawd
    1,089
    Nov 22, 2010
    I've got two sets of ram I want to use on the motherboard. They both have the same 2400 speed but their timings are a tad off. I can make one set match the other in harmony or am I better of just using one set?
    [​IMG]
  2. ryan_975
    ryan_975 [H]ardForum Junkie
    14,205
    Feb 6, 2006
    In most cases, yes. There is a possibility that the motherboard just won't like having mixed RAM though, so you'll just have to try and see if it works.
  3. cyclone3d
    cyclone3d [H]ardForum Junkie
    13,129
    Aug 16, 2004
    I would try it to see if it works.
    I will say that is a total crapshoot though as the subtimings are going to be off as well.
    If you can get them running together at the rated speed, then you are very lucky.
  4. flatty
    flatty Limp Gawd
    157
    Feb 2, 2016
    try "worse' latency for both (in Bios), and after try to see whats happ when you decrease it
  5. rastaban
    rastaban Gawd
    818
    Jul 30, 2011
    They should work together if you manually enter in the timings of the looser modules (11-13-13-31)
