Mix matching these Cards
ElementBilly
I currently have an evga gtx 480. Im going to be buying another for Sli
i have this card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130552&cm_re=480gtx-_-14-130-552-_-Product
for the same price i could buy the GIGABYTE Super Overclock Series
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125350&cm_re=480gtx-_-14-125-350-_-Product
Would i be better off to sli matching cards or would mixing these two be fine.
I Figure for games that don't have sli profiles on release the faster card would be nice.
So would it be fine to sli the two with such different Clocks, I assume the faster would down-clock in sli mode?
apoppin
Pre-Knowing the Pre-Knew Previously
No problems. Beginning with the 260 drivers, the cards can keep their unique clocks and you can change them to match each other - up or down.
Here is a review that does what you want to do but with a Galaxy SOC GTX 480 and a reference GTX 480
PersonalJ
Make sure at least one card is an external exhaust, if the cards have no room between one another in SLI the cooling solutions may not work.
