- Aug 20, 2006
Last year, MIT researchers alluded to a device that would be capable of extracting moisture from very dry air. While scaling and efficiency remains an issue, field tests conducted this week prove that the device is indeed capable of creating drinkable water out of desert air. It has no moving parts and is powered passively with sunlight.
The system, based on relatively new high-surface-area materials called metal-organic frameworks (MOFs), can extract potable water from even the driest of desert air, the researchers say, with relative humidities as low as 10 percent. Current methods for extracting water from air require much higher levels – 100 percent humidity for fog-harvesting methods, and above 50 percent for dew-harvesting refrigeration-based systems.
