Nobu
- Jun 7, 2007
Got my ML-10 in.
Plus side, Looks like I can mount the DE10-nano on the HDD bracket (hanging upside down in the case), although I lose the top (120/140mm) fan in the short case config if I do...wasn't planning to use one anyway.
Otoh, there's really not much room for much else. Planning to put all my I/O on the back, except maybe the USB ports. To that end, there is a punch-out hole for serial on one side, looks like, which I'll probably use for VGA. And I cut a chunk of scrap steel plate to close-enough, and ground it to damn-near-the-right-size for the rear i/o shield where I'll mount the rest. Still need to shave a bit more off and cut holes, but that can wait.
