Well, you could try getting msconfig from several sites that have it for download. At the moment I can't remember where exactly I've seen it but I'll look a bit and see if I can find it.
On the other hand if all you want to do is mess around with the things that startup you could get an app called Startup Control Panel . I haven't actually tried this program yet but I hear it's pretty good and easy to use.
