For those interested, Mint 16 Petra RC is out.
EDIT: It's officially released; altered the link-
All Current Editions | Versions
It booted, but I'm not sure everything works. Kind of torn now between updating non-repository applications and just reinstalling everything. :-/^^ Best wishes getting it worked out.
Hmm not sure about the UEFI thing. I'm on an ASRock Z77 Pro3 here. I installed Mint 16 from a USB flash drive to a Samsung SSD 830 that I had used secure erase on from a USB flash drive. I created that and kept it when I was on Win 7 with Samsung's SSD Magician app. I used the Universal USB Installer 1.9.5.2 to create the Mint installation. I believe I've secure boot disabled in the BIOS. I'm using a 3570k @ 4.6GHz for my CPU. I'm using the x64 flavor of Mint.
I should note when I started my system, I selected my USB flash drive with Mint on it from the boot menu as UEFI (My flash drive info here). The USB flash drive appeared on the boot menu twice, one entry was without the UEFI option and the other had it; I booted Mint live and installed it with the latter option. Tapping F11 while my system is posting is what sends me to the boot menu.
BTW for folks who game on Linux, I highly recommend installing CPU Freq, sudo apt-get install indicator-cpufreq, for Mint/Ubuntu etc.
I set my CPU to the performance option with that app before I game. It makes large difference in Skyrim with the Ultra setting, particularly in cities. Heck, it greatly improves overall smoothness. My CPU doesn't reduce its clock at inopportune times with the performance option set by that app.
I can't boot to the flash drive with UEFI, it just stops at a blinking cursor. If I choose the legacy option it boots right into the live disk setting. I wonder if its an X79 thing or just the Asus UEFI. I'll have to play around with it some more this weekend.
That's odd. It sounds like your BIOS is using legacy mode. That's probably not the case, but something definitely seems off. I'm afraid I don't know much about X79 or your particular mobo. Maybe someone who is more clever than I will stop by.
Have you ever been able to install something like Win 7 or Win 8 in true UEFI mode with that mobo? I installed Win 7 in true UEFI mode from a USB flash drive on this ASRock Z77 Pro3 to my SSD 830 without issue. I selected the flash drive as UEFI like I did with Mint. I was using that before Mint. I should note, I couldn't install Win 7 in true UEFI mode to my SSD 830 with any other disks connected. It had to be the sole disk online at the time. I disconnected my backup disks when I installed.
Yeah, thats how I did 8.1 and it works fine. I don't have fast boot with it being X79, so the UEFI is kind of just shoved in there as an after thought. Tonight I'm going to mess with it some more, I'd really like to get it working.
A few ideas; make sure OS type is set to Other OS in your BIOS, disable SATA controllers that aren't Intel. If that works try to install it. Obviously, use x64 Mint. This guide is for Windows and UEFI but some of it still may be useful to you.
