Hi, all.
I've hit two snags with putting together my Lian-Li PC-Q03 with my Asrock H81M-ITX.
-1- The front panel of the case has a group of several small connectors that go from the power switch to a panel on the motherboard, and the three sets of connectors are labeled Power LED, HD LED, and Power SW. The Power SW is a double-headed plug, which I believe should link up to the space on the motherboard that says "PWRBTN". The problem is there is only one space/slot for PWRBTN on the mobo, and the two adjacent spaces are labeled "GND" (which, I have no idea what that means). Any suggestions? If plugging in this Power SW is mandatory, it seems like my only option is to plug in one of the Power SW heads into PWRBTN and another head into GND. Could this be correct, and if so, does it matter much which of the two GND slots I use? I assume part of this Power SW plug must be +/-. Thank you.
You can see an example of the mobo panel in the link below (PWRBTN is in the center).
http://imgur.com/jR7x9
-2- The front panel has another connector, which is a 20-pin, labeled "FY", that apparently has something to do with the USB 3.0 connections. It seems as if Lian-Li wants this to plug into a USB 2.0 header, which then plugs into the mobo. I assume that my speeds will still be USB 3.0?
Thanks very much.
Thanks very much.
