Last I looked there wasn't even an mATX board supporting passthrough from AMD, quick look at newegg confirms. With AMD you want 890FX or any 9 series chipset. With Intel Q67 boards are officially supported and there are options from actual Intel in mITX form. Unofficially some board makers with other chipsets have the option in the BIOS, whether it actually works is another matter.
FM2 boards support IOMMU on a hardware level. Some of them might require a BIOS update to enable it.
I don't think their are any AMD motherboards that are min-ITX that support this
Guys? The Asrock FM2A85X-ITX was mentioned like 5 posts back. It is an AMD board. It is ITX form-factor. It supports IOMMU with a BIOS update. Any board with an FM2 socket has this capability, but some may not enable it in the stock BIOS.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157357
