So I have an image file I tried burning to a DVD and was going to use but the burn failed (don't know don't care).
So I figured I'd go get some app that can mount .ISO files as a virual drive. I've never had the need until now but I know they are out there. I've occasionally used Nero's Image Drive to do that sort of thing with their .nrg images but didn't want to convert this one.
I did a google search on Mount ISO image and found this page:
http://weblogs.asp.net/pleloup/archive/2004/01/15/58918.aspx
Sure enough Microsoft has one and I had my .iso mounted in under 30 seconds without a reboot or anything... works great!
Check it out for yourself. I'll report back as I use it but by default it mounted it as the W: drive which is fine by me. (although I'm sure I could have changed it if I really wanted)
(Microsoft Direct Link to the page)
http://download.microsoft.com/downl...d58df02efa2/winxpvirtualcdcontrolpanel_21.exe
