- Aug 20, 2006
You are in luck if you are itching to upgrade your Surface Pro 4, as its successor is due out within months. One of its major selling points may be an Ultra HD display, although I’m not a fan of that decision, with it being a smallish device that should have just kept resolution the same for better performance.
Pegatron will be manufacturing the device. Pegatron is similar to the more infamous Foxconn and they've become the preferred manufacturer for a number of other products like the iPhone. The report also says that the Microsoft Surface Pro 5 will feature an ultra-HD (3840 × 2160p) display which is a vast improvement over the Surface Pro 4's 2736 x 1824p display. This change will see an increase in PPI from 267 to 358 representing a 34% improvement. We may also see a magnetic charging stylus on this generation of the Surface Pro. The rumor further indicates that the launch date for the Surface Pro 5 will be in the first quarter of 2017, which could be as late as March.
