HardOCP News
[H] News
- Dec 31, 1969
The folks at iFixit have posted a teardown of the Microsoft Surface Pro 3. I snagged a few pictures for those of you too lazy to click the link.
I thought they put a socket in that board but then I saw the picture without the heatsink and realized no they didn't. I hate that.
You should hate that to take it apart you need to separate it from glue/tape way more than a low profile tablet soders the cpu directly to the board.I thought they put a socket in that board but then I saw the picture without the heatsink and realized no they didn't. I hate that.
Gabe over at Penny Arcade recommends not buying it that there is lag and many other issues.
Whatever huge knock against surface. A device that can clear 2k is going to be a brick when the battery craps out. And this device seems to go further than apple to make sure its planned obsolescence. You are going to destroy the screen to get to ANYTHING in the device. Be warned to buy an extended warranty with this device which covers your max use case and resale desires.
They layout of surface is completely unneeded. They could have separated the back and left screws to open it up without adding any height and this would have at least exposed many internal component and even left the option for surface displays to come with the surrounding support ring and display as a unit for everything else to be dropped into. This is already a somewhat niche device so no one is going to want to work on it.
What has your experience been so far pressure wise?
Thats a really silly complaint... You going to destroy your surface to upgrade the CPU?
Even when charged daily the battery still has 80% of it's capacity after 4.5 years. That would probably cover the life of the device for most people and then some.
FWIW, the Surface Pro 2 (and Pro 1, obviously) does not have many of the same issues the Pro 3 does.
It's a Wacom digitizer instead of N-trig. Doesn't have the weird thin screen. 'Start' button is centered on the bottom instead of the side. Etc.
Of course, it's a smaller device, but...IMHO, it works pretty darn good.
Personally, I think I'll wait for
I've read dozens of threads on the Surface Pro 3, some in depth, some not, but the general concensous is that people are confused with the choices MS made with the Surface Pro 3.
I really hope Microsoft has someone that's a community liaison of sorts that will find all these complaints and concerns, pass it on the engineers and get it right with the Surface Pro 4.
I'm not seeing anyone confused about the bigger and better screen or reduction in weight or the free motion kickstand. There are some wondering about the move from a Wacom to N-trig pen but the main reason for that was around reducing thickness from not needing an layer under the screen. Reports of pen performance are generally good with the main issue being the needing configurability of the pressure curve.
Other then the pen input issues brought up with artists I'm not seeing anyone complaining about the Tablet other then the usual haters.
It does look as though Microsoft has pending solutions for pen issues. The pen can disable the Windows button when in proximity now, Gabe from Penny Arcade saw that in action and said it worked perfectly on the SP3 that Microsoft gave him to test out though they didn't have a way to deploy it when Gabe was testing. And Microsoft did make some progress with the pressure curve issue and think they can straighten out the lag Gabe was seeing. I can kind of see Megalith's point, the Windows button being disabled by the pen should have been there from the beginning but pen issues with Windows devices out the gate is unfortunately nothing new. It's still kind of finicky technology even after all of these years. Even with Wacom pens there's issues, especially with precision along the edges with N-trig digitizers don't generally have because the pen emits the signal rather than the a layer in the screen.
Regardless of these 'glaring' issues that keep getting brought up, its the best touch/pen device I've used yet.
I've not had an chance to try the pen yet. I was impressed with the engineering and build quality and the screen with my brief time trying one out at a Best Buy. Some knucklehead had stolen and ripped the pen off its tether so that's why I didn't get to try it. But from all that I've read and online video I've seen, the pen is quite excellent overall. The pressure issue won't effect me as I am mostly want the pen for handwriting.
Yet the Surface 1&2 were, in some ways, better.
Which is frustrating, as it seems like '2 steps forward, 2 steps back' with Microsoft.
Hard to see how the SPs 1 & 2 are better in any significant sense.
Have you tried using both?
The screen, when 'inking', on the Surface 3 is HELL compared to the Surface 1/2. That 'thinner' display panel leads to serious, and very easy, warping. (Oh, and you get a heavier pen, besides - and as we all know, when it comes to weight, what's more important is the weight of the device sitting on the desk and not the one you are holding in your hand...)
Nevermind the thing feels practically like a furnace compared to the Surface 1/2.
And that button on the side...even aside from the stupidity of placement on it from the 'accidental bumping' aspect (forget using the pen - that's pretty much exactly where I put my THUMB when just holding the thing for regular web browsing), the aesthetic of that annoys me to no end. It's a Windows device, it's mean to be used horizontally, a centered button goes ON THE BOTTOM. (Ohnoz - you can't access the 'Windows' button when the keyboard is attached?! Who cares - the keyboard HAS ITS OWN 'Windows' key!)
Sure, the hardware is technically better. And who can argue with a larger display? The design it's wrapped in, though...decidedly inferior to its predecessors.
That's assuming the battery will hold it's charge to spec and work as advertised / designed / engineered.
There are just too many unknowns. Many of us have been burned before in this manner. I have a 3 year old Apple 3GS phone in perfect condition that I wanted to give to my friend. It had no value but still looked and worked perfectly. Only when I pulled it out of the closet the phone had separated because the battery had bloated / swelled up destroying the phone in the process ( true story )
It's no secret that more so than ever, manufactures are building in / designing their devices to become obsolete. It's called Planned obsolescence or built-in obsolescence and you can read about it here - http://en.wikipedia.org/wiki/Planned_obsolescence
Basically what has happened with the Surface Pro 3 and it's battery is that they want you to buy sooner rather than later. Much much sooner.
I have many things in my home that are well over 5 years old and electronic that I still use or have passed on to family or friends to use. Of course now, manufactures are realizing they are losing money and are trying to change consumer habits by being more aggressive in this area.
Here's a good example. let's say you have newborn son or daughter that's 6 months old. Being a young adult / adult and drawing upon your own experience as a child and the fascination in art that most of us had, you know that one day you will want to be able to give your 6 or 7 year old Surface Pro 3 to your kid to do art projects on. But you can't because the battery has long ago died and you can't replace it.
We are talking $1,080 dollars here.
Personally, this bothers me.
In 6 or 7 years you'll be able to buy a low end tablet that is as if not more powerful than the current surface pro's for less money than it would cost to buy a battery for a 6 or 7 year old high end tablet even if the battery were replaceable.
