Shift+F10 still works, I used that just 2 days ago to install W11 on a mini pc and it works fine.Does Shift+F10 no longer work?
I’ve always just used that.
But it’s been a hot minute since I’ve installed home.
I use OEM keys, and an OEM Home key is cheaper than an OEM Pro key, it's not rocket science. In this day and age with cost of living issues out of control, $20.00 can mean the difference between getting the quote over the line and not getting the quote over the line, if a client has no need for the 'features' Pro offers, there's no point quoting on Pro - I know how to run my business.
Pretty soon, every version of Windows is going to suck.You can install what ever version you think is profitable for your customers, but the question is what you (clearly a poweruser) use in your OWN system? If you use Home edition then you are at the mercy of Microsoft. Pro version atleast allows you to have local account without work arounds but from gpedit you can also disable automatic windows updates and other annoyances Microsoft force on you and so on. Home edition is not worth it for us who like to use our operating systems in OUR way.
That said, Microsoft has been busy gimping Pro edition too at every chance they get.
Rufus still works fine with the latest build.Anyone tried Rufus yet with this newest build?
I use Linux, Windows interests me about as much as herpes.
Then this discussion doesn't concern you. But as Linux user you are familiar with having absolute freedom over your operating system, something Windows also used to have but is slowly being eroded. Pro version still has SOME semblance of user freedom and control but Home has none unless you resort to hacks.
And yet that fat part of the Windows user bell curve still has no need for Pro. As such, stating that the fix is to use Windows 11 Professional is nothing more than deflection away from the real problem. Having said that, the main problem regarding Home is the fact you can't use the join a domain trick to create a local account on install, but there are still ways around that.
Honestly, the real problem is that Microsoft are becoming somewhat sucky. I'm not making such a comment because I dislike Windows (even though I'm definitely not a fan), I'm making such a comment as it's irrefutable.
Compared to Linux, even Pro has little in the way of true freedom, privacy and ownership. As someone supporting Windows based systems, this discussion definitely concerns me - In fact, the outright ignorance of modern society concerns me, it's one of the reasons we're in this own nothing and be happy mess to begin with.
Windows 11 IoT Enterprise LTSC 24H2 is what you want. ;-)
The place rhymes with pass save. ;-)Is it available for regular people to buy or do I have to sail the high seas for it?
Can you explain further, so I can justify the extra expense on a new system.. Pro version still has SOME semblance of user freedom and control but Home has none unless you resort to hacks.
https://www.digitaltrends.com/compu...browse the web, and use everyday applications.Can you explain further, so I can justify the extra expense on a new system.
Nice, but I guess I should've added "and confirmed it can still block the Microsoft Account requirement". I figure it most likely does, just thought confirmation would be good.Rufus still works fine with the latest build.
Yes, it does.Nice, but I guess I should've added "and confirmed it can still block the Microsoft Account requirement". I figure it most likely does, just thought confirmation would be good.
Yes. This is an alternative. You can create a local account and then delete the other account. Making a throwaway Microsoft account works just fine for this purpose, since Microsoft seems to not allow the normal dead account methods to work (such as fake@fake.com and no@thankyou.com).I've never used the Home edition but, couldn't you just create a local admin account after installation and then only login to that account from then on? If you don't want Microsoft to know your email address there's a number of sites that provide throw-away email accounts (good for 24 hrs or so) you could use for the install email address.
Yes, but don't let that get in the way of a good whinging! You don't need to even keep the online account, it can just be deleted after you make the local one.I've never used the Home edition but, couldn't you just create a local admin account after installation and then only login to that account from then on? If you don't want Microsoft to know your email address there's a number of sites that provide throw-away email accounts (good for 24 hrs or so) you could use for the install email address.
If you don't create/use an MSA, they won't keep your bitlocker key for you, which is really annoying. My last company let me keep my laptop when they laid me off, after force-wiping it. A neighbor needs a new laptop so I offered to sell it to her, but in the meantime I had put a new SSD in it with Linux. I went to swap them back yesterday and Window refused to boot without being given a bitlocker recovery key (apparently the BIOS was set up to enforce using Bitlocker). I was able to get the key because I was too lazy to go to the trouble of doing the workaround.Yes, but don't let that get in the way of a good whinging! You don't need to even keep the online account, it can just be deleted after you make the local one.
lots of business machines do that. any machine we have that might contain student info is forcefully encrypted.apparently the BIOS was set up to enforce using Bitlocker
still workin.Shift+F10 still works, I used that just 2 days ago to install W11 on a mini pc and it works fine.
I can also confirm this still works. I've just been using Rufus lately, so I didn't notice.still workin.
just had to do a home reinstall. created a new 11 usb from a fresh dl of the creation tool, booted, let it pick up the key from the uefi, install stopped at "no internet". did shift+f10 entered, oobe\\bypassnro, it rebooted and then it gave me the continue without internet button.
Now just need to spread the word that you don't need to add a password to the local account at creation, that way you can bypass the whole 3 security questions part, then just Ctrl-Alt-Del and change password after first login.still workin.
gave me the option to skip it. so its on a local account, no pw, and boots right to the desktop. i also dont see any of the "ads" people are always screaming aboot...Now just need to spread the word that you don't need to add a password to the local account at creation, that way you can bypass the whole 3 security questions part, then just Ctrl-Alt-Del and change password after first login.
I swear those questions are the worst.
still workin.
just had to do a home reinstall. created a new 11 usb from a fresh dl of the creation tool, booted, let it pick up the key from the uefi, install stopped at "no internet". did shift+f10, entered oobe\\bypassnro, it rebooted and then it gave me the continue without internet button.
ok, two still works.You only need one backslash.
Bypassnro still works, but default networking drivers won't be installed. You have to install networking drivers from your own media once Windows has installed.
That’s crazy, I can see a WiFi with the same name down the street from me.ok, two still works.
that might depend on whats built in for a nic. this system pnp'd just fine. plugged in the cable when i was at the desktop and carried on with updates.
edit: and it pnp'd the wifi, it saw mine fine, and "prettyflyforawifi" down the street.
do you see a "strangewhitevan" or "russianspyvan"? we might be neighbours!That’s crazy, I can see a WiFi with the same name down the street from me.
"fbisurveillancevan" chiming in... Welcome to the neighborhood!That’s crazy, I can see a WiFi with the same name down the street from me.
That's not shady at all.That’s crazy, I can see a WiFi with the same name down the street from me.
This is the command:this is still working, with a little modification to the method:
cd oobe
msoobe \bypasnro
just did it on a 10 home, at first i got "oobe doesnt exist", because they moved it....
oobe\bypassnro
works with or without the space and oobe has been renamed to msoobe and moved into a new dir. this happens if your installer is up to date or its online during setup.This is the command:
Code:oobe\bypassnro
I don't know if it works in Windows 11 Home, but it certainly still works in Windows 11 Pro as I did it yesterday.
Needs both esses, though.works with or without the space.
yes, the typo was corrected a while ago(45min)....Needs both esses, though.
so are google and apple...Microsoft is so f'ing hell-bent on getting your data.. and getting you to use a Microsoft account.
