My neighbors and I would like to set up a mesh network to share access to a PBX and some simple file sharing. Line of sight point to multi-point is really out of the question. No one has a tower tall enough to be seen LOS from more that 1 or 2 houses because of some really really tall 200 year old trees. All the houses can see each other, even the ones that are far apart, but a base station would be very impractical and expensive because there would have to be 8 backhauls for 16 houses. I've been looking at open-mesh for a bit now, and I like the way their software is set up, as well as their firmware but their hardware is going to be lacking for my needs.
I know that we need to go with dual band AP so the backhaul can be on 5GHz and the client can be on 2.4GHz but some of the houses are about 125 meters from each other. Even placing their dual band AP outside is going to be stretching it's ability, especially since you can't change antenna's or anything (so it appears).
What I am looking for is a mesh configuration that uses dual band AP's that I can change both the antenna's on. I can put an omni on the 2.4 and a directional on the 5ghz and use one piece of hardware for both the client side and the backhaul.
Only 4 or 5 of the houses would need an AP with a directional antenna, but I want everything to work seamlessly and all under the same system.
Also, does open-mesh support mult-wan?
Any ideas or different solutions to create a high speed backhaul and still deliver 40-50mbps to the client for 125/ap or under?
