Is Patriot correct here? Figured the [H] would know. My last build was on DDR1 so some of these timings are foreign to me. Thanks in advance guys.
Motherboard: Asus P5P43TD (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131607)
Memory: Sector 5 G series 4 GB 2x2GB PC3-10666 1333mhz (http://www.newegg.com/Product/Product.aspx?Item=N82E16820220435)
My Question:
I have a question concerning some BIOS settings for these
ram sticks. It appeared that my board set the timings to 7-7-7-24 for
1066 mhz. When I move it to 1333 mhz it sets the timings to 9-9-9-27. No
biggy as I adjusted the row to 7-7-7-24, but I have no idea what to do
for the second and third row of timings. Also there are some timings on
the first row that I am clueless about? My bios looks like this:
http://www.overclockersclub.com/reviews/asus_p5qle/images/18.htm
Patriot Response:
The other values for the memory settings you do not need to adjust. The
only 4 settings you need to be adjust are TCL, TRCD, TRP and TRAS.
Thank you for choosing Patriot Memory.
My Question:
Patriot Response:
