SavageThrash
- May 16, 2007
Alright guys I come to the only forums that ever seem to provide useful advice in a timely matter with an issue that I am totally lost on. It involves reprogramming the spd on some ddr 2 so-dimm, heres where Im at.
I have 2 tester sticks of unlocked eeprom ram and i want to keep the sticks at the looser 333mhz (pc2-5300) timings whilst running them at 266mhz (pc2-4000). The issue im having is that the software Im using (thaiphoon burner) allows me to adjust timings via ns. Now when i set the memory to 266 the timings in the software automatically jump down to the proper 266 timings.
I want to set them back to the 333mhz timings however the timings in what i call standard format (5-5-5-15 for example) have MANY sub settings within the ns bracket that im using to adjust. Let me use tRCD for an example. It is set to 15.00ns and that gives me a timing of '4t'. The 333 spd is a 5t for tRCD however I have the option of anywhere from 15.25ns to 18.75 ns under the 5t timing. The software doesn't give me the ns timing of the 5t 333mhz setting so I'm lost as to what I can/should set it to. I thought the best route would be to just set them all at the very loose end of the spectrum (18.75 ns) but I have a feeling that if i do that with all the timings that maybe something wont match up and cause the stick to function improperly/very poorly.
If you guys have read all this I thank you very much and appreciate any insight you can give. If theres something i haven't explained well enough let me know and i can get some screenshots of the software in here as well but for now I need to sleep this nightmare off and hope for some help from you guys in the morning
