I got 2 older computers that I am looking into picking up used memory for. Upon reading the manual/specs for each, it sounds like they can only take 128mb sticks. One motherboard has the 440BX chipset and the other had a VIA MVP3 chipset. I found a couple of charts on the net tho that say the 440BX can handle upto 512mb and the MVP3 up to 1GB. Is this correct? Can the chipsets take 256mb sticks? The 440BX board only has 2 DIMM slots and a Slot1 CPU. The VIA MVP3 has 3 DIMM slots and a Socket 7 CPU. Do I need to look for low-density modules for these or will anything (SDRAM (PC100/133)) work?
TIA for the help.
EDIT: OK now I am seeing that the 440BX can take upto 1GB and the MVP3 upto 768mb. I am assuming that the 440BX canNOT handle 512mb sticks tho so it would be limited to 512mb max IF 256mb sticks work. The MVP3 on the other hand might be able to handle the 256mb sticks on all 3 DIMM slots for the 768mb's. Correct?
TIA for the help.
