I have a Q6600 running at 3.6Ghz on an Asus P5K vanilla. Now it is running at 400x9. I just bought an OCZ Reaper HPC Edition DIMM Kit 4GB PC2-8500U CL5-5-5-18.
The question is do I run the ram at 800Mhz using 1:1 ratio with tighter timings or use a divider to run it 1066Mhz with stock timings? Which one is faster? I did my research on these forums and by googling by I cant seem to get a clear answer. Some said its best to stick with 1:1 and some said its best to for the fastest speed. Im confused.
TIA!
TIA!
