I got a SAS-9280-4i4e raid controller that is sitting in a Supermicro 826 chassis and internally connected to a BPN-SAS2-826EL1 backplane. The 9280 is running the latest firmware from Avago's site (dated August 2015). The backplane is running the 55.14.18.0 firmware from June 2013, which is the latest I could find.
The controller is seeing the 12 disks on the backplane just fine, but I keep getting the following error message every 10 seconds in the MegaRAID Storage Manager console:
Controller ID: 0 Unexpected sense: PD = 70-Invalid command operation code, CDB = 0x1c 0x01 0x01 0x00 0x20 0x00, Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x02 0x00 0x00
It does not appear too serious having an Information error level. However, in the Dashboard, it is showing I have no Enclosures and no Backplanes. Also, on reboot, I get a critical alert stating that I have an Unstable Enclosure.
I proceeded to connect my 2 external Supermicro 846 chassis (with BPN-SAS2-846EL1 backplanes also running firmware 55.14.18.0) that are daisy-chained together since the 9280 only has a single external SFF-8088 connector.
Anyway, after adding those, I'm not getting entries for each of those backplanes in the log as well:
Controller ID: 0 Unexpected sense: PD = 83-Invalid command operation code, CDB = 0x1c 0x01 0x01 0x00 0x20 0x00, Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x02 0x00 0x00
And:
Controller ID: 0 Unexpected sense: PD = 108-Invalid command operation code, CDB = 0x1c 0x01 0x01 0x00 0x20 0x00, Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x02 0x00 0x00
I went ahead and build my 60 disk RAID60 array (5 spans with 12 disks each):
The init is chugging along and is close to 50% done this morning after starting it last night.
So should I be worried about the log entries that are coming in every 10 seconds or the critical error about "Unstable Enclosures" (I got 2 of them now since adding the external ones).
Is there a newer firmware available for the Supermicro Expander backplanes that will correct this?
Thanks
And:
Thanks
