My trusted Razer Death Adder that I've had for 3-4 years finally got the dreaded "double click" where it clicks everything twice and makes it unusable. I also have a cheap Walmart keyboard where the numpad no longer works and it's all rubber domes/membranes under the keys so I will be upgrading immediately.
In regards to the keyboard, I want either Green or Blue switches. Most recently, I owned the Razer Blackwidow Ultimate which had Green switches and I liked it a lot. I've also tried blue, brown, red, etc. and greatly prefer the tactile feel and clicking sound of the greens or blues. I usually end up with either Razer or Logitech when it comes to gaming peripherals as they've always been dependable and are at acceptable price points for what they offer. What would you guys recommend?
In terms of mouse specifics, I have large hands and am somewhat particular about mice but I live in a small area with nowhere near me to try anything out. I also play a lot of WoW and decent amount of LoL with much school work thrown in but I don't play FPS at all. For reference, I have used the Logitech G700s, Logitech G500s, and Razer Death Adder which all were great, especially the G700s and Death Adder. They fit my hand perfectly and are made out of solid, matte plastic material which means they don't slide or feel awkward in my hand. I have also used the Logitech G502 and G600 (MMO/MOBA Mouse) and did not care for them. The G502 was extremely small, made out of some type of cold, slippery plastic, and felt cheap & uncomfortable. The G600 was okay but it was too tall for the width and length due to fitting 12 buttons on the side. I like the design or something similar but it was not made proportionately correct.
After looking around on both companies' websites (I'm open to other brands but generally like to stick with reputable / dependable brands.) it seems like these are the options I have found that caught my eye: (Once again, these will be for solely World of Warcraft (MMO) and League of Legends (MOBA) game wise and a lot of typing as I'm finishing my Business & Accounting degrees so I need the numpad which rules out tenkeyless.)
Keyboards
Logitech G910
Logitech G613
Razer Blackwidow Chroma V2
Razer Blackwidow X Chroma (I think the above one is the new version but wanted to be sure.)
Mice
Razer Naga Trinity (Can swap out 3 different side plates for multiple button configs)
Razer Naga Hex V2
Logitech G903 / G703
(Do they or anyone else have anything similar to the Razers in terms of MMO mice? I'm afraid to try them after how much I disliked the G502 and they look similarly built. What do you guys think here? Any Logitech mice that are excellent or other brands to consider?)
MousePad
Razer Vespula V2 (Has Cloth Side + Plastic Side and a solid Wrist rest which I appreciate since I have a bad wrist.)
Let me know what you guys think. Thanks for the help!
Keyboards
Logitech G910
Logitech G613
Mice
Razer Naga Hex V2
MousePad
