Hello all... Just built a MCE2005 box:
Currently using:
AMD 3200 512K 754
Western Digital 250GB SATA HD
1GB Mushkin 3500
Abit KV8Pro http://www.abit-usa.com/products/mb/products.php?categories=1&model=176
Sapphire 9600XT 256MB w/Svideo & RCA Out
http://www.newegg.com/Product/Product.asp?Item=N82E16814102344
Hauppage WinTV-PVR-500MCE (http://www.hauppage.com/Pages/products/data_pvr500mce.html)
Sound Blaster Audigy
http://us.creative.com/products/product.asp?category=1&subcategory=205&product=237
TV- 42Inhc Toshiba HDTV Ready Rear Projection - Has Svideo/RCA/Composite
A couple of questions:
1. Does anyone notice the difference in quality between Svideo and Composite? Does it make a noticable difference when viewing txt or even movies?
2. What if any extra codecs do you recommend installing? Ive read alot about people unable to get Divx/Xvid playback working at all, or if they do it wrecks normal playback of everything else.
3. Does anyone recommend this card: http://www.newegg.com/Product/Product.asp?Item=N82E16814145107
over the card Im currently using? Biggest difference is Nvidia over ATi and having the ability to connect to the TV using Composit/RGB cables.
Thanks all in advance for advice,
Skids
Currently using:
AMD 3200 512K 754
1GB Mushkin 3500
Skids
